Da-Lite Screen Company is pleased to introduce a new series of thin flat panel wall mounts. These mounts are designed for easy installation and are virtually invisible once installed. The TWM series is a tilting mount design and allows for adjustment from 0 to 15 degrees, while only protruding 11/16" from the wall at 0 degrees. The TWS series is a static mount design which only protrudes 7/16" from the wall. The TWM and TWS series are available in two sizes. The 2000 models fit most 19†to 27†diagonal flat panel monitors, while the 2800 models fit most 27†to 65†diagonal flat panel monitors. Both feature a universal mount design that accommodates most thin displays.
Discuss "DaLite TWM and TWS Series Flat Panel Wall Mounts Preview" here.
Read the article.
