Westinghouse Unleashes the $979 VR-5585DFZ LCD TV
admin
Audioholics Robot
Staff member
Westinghouse Digital has announced it will ship a new 55" LCD HDTV at just $979. At that price, it makes owning a spectacular big-screen flat panel TV an affordable reality for consumers everywhere. The VR-5585DFZ seems to have arrived just in time for the holiday season. The new VR-5585DFZ Westinghouse LCD HDTV is a 55" HDTV that features full 1080p high-definition resolution and 120Hz with MEMC (motion estimation/motion compression) to ensure smooth images by reducing judder and blur.
Discuss "Westinghouse Unleashes the $979 VR-5585DFZ LCD TV" here. Read the article.
3db
3db
I hate it that manufacturers can't get their proverbial sh?t together and standardize on specs.
What's the contrast ratio both dynamic and static? What is the respsone time in ms? If they are not publishing these specs on a display, it makes me wonder what they are hiding. At least you get these last two specs with every Vizio LCD/LED product.
Picture Quality
Screen Size: 54.6″ Diagonal
Native Resolution: 1920 x 1080
Aspect Ratio: 16:9
Contrast Ratio: 1400:1
Viewing Angle: Horizontal 176° / Vertical 176°
Compatible Modes
TV Tuner Capability: NTSC, ATSC, QAM
YPbPr: 480i, 480p, 720p, 1080i, 1080p
HDMI: 480i, 480p, 720p, 1080i, 1080p
PC: SVGA, XGA, WXGA
Optimum Resolution: 1920 x 1080
Electrical/Power Connections
AC Power: 100-240 VAC 50/60Hz
Power Consumption (max): <250 watt
Power Consumption (stand by): <1 watt
Connections
Antenna In (RF): 1
Video (Composite): 1
YPbPr: 2
HDMI: 3
VGA: 1
PC Audio In (mini): 1
Audio In (Dual RCA): 2
Audio Out (mini stereo): 1
SPDIF Out (optical): 1
AC Power In: 1
Features and specifications subject to change without notice.
Mechanical
Wall Mount: VESA 400mm x 400mm
Weight with stand: 78.26 lbs
Dimensions (WxHxD): 52.0″ x 34.5″ x 11.8″
Weight without stand: 48.5 lbs
Dimensions without stand (WxHxD): 52.0″ x 32.2″ x 4.49″
Carton Weight: 95.9 lbs
Carton Dimensions (WxHxD): 56.25″ x 39″ x 8.5″
Cabinet Color: High Gloss Black
Video Features
120Hz: Yes
Screen Fit Modes: Standard/Fill/Overscan
Progressive Scan: Yes
3D Noise Reduction: Yes
Inverse 3:2 Pull Down: Yes
De-Interlacing: Yes
3D Adaptive Comb Filter: Yes
2D OSD Graphic Engine: Yes
Selectable Color Temperature: 3 Presets
Audio
Speaker Qty: 2
Watts: 10
Certifications and Compatibility
FCC Class B, CE, UL, CUL
