True wireless outdoor solutions like the Klispch AudioRock add-on for the LightSpeaker system are rare and always impressive. Since the AudioRock is an add-on to the LightSpeaker system you'll have to fork over $600 before you can shell out $200 more for the AudioRock. They are rated down to 65Hz with dual 0.75-inch polypropylene tweeters mated with a 5.25-inch injection molded polypropylene woofer. All the drivers are angled 20 degrees up to account for the inevitable ground placement. The AudioRock is constructed out of a UV-protected, weatherproof, and rustproof plastic with a gray faux-granite finish. The speaker is designed to withstand the elements (and sprinklers) as long as it is not submerged in water or left to sit in more than an inch of water.
Discuss "Klipsch AudioRock Outdoor Speaker First Look" here.
Read the article.
