System Type 2.5-way floorstanding, magnetically shielded bass reflex with front-firing port
Frequency Response 39Hz - 20kHz
Recommended Amplifier Power 20-250 W /channel
Impedance 4 Ohms min / 8 Ohms nominal
Tweeter 1-inch (25.4mm) hyperbolic aluminum-dome
Woofer 3 x 5.5-inch (140mm) w/Ribbed Elliptical Surrounds
Sensitivity (2 speakers in a typical room) 96dB
Crossover Point 2kHz, 1.2kHz
Inputs Dual gold plated 5-way binding posts
Overall Dimensions HxWxD (including feet)
38.6 x 7.1 x 14.6 inches
98.1 x 18 x 37cm
Weight Product: 39.3 lbs / 17.8 kg (each)
Packed: 45.3 lbs / 20.5 kg (each)
Finishes High gloss black baffle with black ash cabinet
Included Accessories Manual, port plugs
These look to be better built then their latest Veritas update... I see their efficiency is way up too.. I still withhold my judgement on these until I hear them based on my prebias that Klipsch got their mits on these.
