Hotech's VoiceMe II is a voice-activated and controlled universal remote. At first we thought you'd have to have IR flashers running all around your home but that doesn't seem to be the case with the VoiceMe II. Instead, you put the unit in the room and it blast the IR signal in multiple directions. The VoiceMe II can be programming with up to 120 commands and can recognize four different users and claims a greater than 95% accuracy for voice recognition. Up to 10 operations can be activated by a single command. The VoiceMe II has the ability to delay commands as well which is important so that multiple commands to the same device aren't ignored if the device isn't ready. Now if they could get someone that sounds like Majel Barrett-Roddenberry to do the voice....
Discuss "Hotech VoiceMe II Home Control System First Look" here.
Read the article.
