There is a lot to like about the Atdec TH-400-LED mount. From an ease of use standpoint, there is very little that can beat it. If you can hang a heavy picture, you can use the TH-400-LED. But there are some considerations as well. You need to think about the orientation of the connections, about how the location of the mount will affect viewing angles and reflections since it can't be tilted, and how likely the display is to move on that wire. That being said, the TH-400-LED only costs $89. For a mount that will allow you to place your new flat panel only 5/8" off the wall, that is very reasonable.
Discuss "Atdec TH-400-LED Slim Flatpanel Mount" here.
Read the article.
