Elemental Designs A3s-250 Subwoofer First Look
admin
Audioholics Robot
Staff member
The A3s-250 is Elemental Design's attempt to build a reasonable sized sub. At just a bit larger than a 14" cube and a matte black finish, the A3s-250 should have little problems disappearing into a corner or shadow. Your spouse will like that. Of course, you'll like when it starts rocking your room and shaking the pictures loose. Sounds like a win, win to us.
Discuss "Elemental Designs A3s-250 Subwoofer First Look " here. Read the article.
KEW
KEW
They offer a nice discount of $300 ea if you buy 2 or more.
2 of these for $600 seems like a decent option for music (because of 25Hz roll-off).
gene
gene
Audioholics Master Chief
Administrator
25Hz is a -3dB point. Its a sealed design so it probably has a very gradual roll off below that and factoring in room gain it should be just fine for home theater duties in small to medium sized rooms as well. This is especially true if your running a pair of them.
