Dynaudio Unveils Sub 3 and Sub 6 Smart Subwoofers
gene
gene
Audioholics Master Chief
Administrator
If you're a Dynaudio fan than things just got better for you. Dynaudio recently released their Sub 3 and Sub 6 at CEDIA in San Diego, California. The Sub 3 and 6 are designed to match seamlessly with your Dynaudio speakers… intelligently. Both subs feature brand-new driver designs, sophisticated DSPs and full parametric EQ to help ensure a tailor-made fit for your set-up. Are the everything that Dynaudio claims them up to be? Read on to find out.
Read: Dynaudio Unveils Sub 3 and Sub 6 Smart Subwoofers
Two-way to Three-way built in blending maps. Interesting idea. I'll guess many manufacturers will likely move to some form of this sort of strategy going forward.
That is the correct approach in my view. A sub really does make a 3 or four way system. Generic crossovers never really work. An integrated approach like this has everything to recommend it. I have never heard a Dynaudio speaker I did not like. I have long thought we do not recommend them enough on these forums.
All Dynaudio drivers are very well made. Their speakers should be high up the rec. list.
panteragstk
panteragstk
I've only heard the Dynaudio recording monitors and all were fantastic.
gene
gene
Administrator
I have heard/reviewed a couple of their bookshelf speakers and liked them.
However, I heard one of their flagship speakers where the tweeter below all of the other drivers for some bizarre reason and they did not sound good. I wonder if the designer of that particular model accidentally turned the cabinet upside down when marking the build plans to put the threaded inserts for the feet :)
I think you are referring to the Dynaudio Consequence speakers.
I have history with those. They first appeared in 1984, they were later revised and the drivers changed to the esotar range, and the isobarik bass unit enlarged a little.
The reason for the driver layout is because these speakers use first order filters and are time aligned. This means the lobing tilt axis is upward.
All the early work was done on these speakers while I was developing my previous studio speakers, started in 1976, and went on for around a decade. I was following a similar path and used three Dynaudio drivers. The M75, D52 AF and D21 AF. In 1984 I used my first modelling software in an Apple 2E computer! Anyhow those were early days, and I had generous help from the good folks at Dynaudio. Despite computers there was a lot of touching up by ear!
Anyhow I made mine taller and had the tilt downwards. I'm still using these speakers.
The bass section is 2 KEF B 139s in a TL. The crossover to the M75 is active at 180 Hz. This is not first order because of the violent resonance of the KEF units above 900 Hz.
The other crossovers are all first order. The Dynaudio team suggested the unusual series network for the cross from the M75 to D52. There are just seven components in this passive crossover.
The M 75 is in a totally damped line.
The tweaking of this crossover and driver offset went on for years. However they became really nice speakers. Bob Carver spent an afternoon with them when he was in town setting up an early pair of his ribbon speakers for a cardiologist colleague. He really liked those speakers.
When I moved out of Grand Forks, I did not want to scrap them and rebuilt the bass line to take advantage of George Auspergerer's mathematical TL model.
The dispersion pattern of these speakers is ideal for HT in that position and they really get to shine in works like the SACDs of Britten's War Requiem where there is a large orchestra up front with choir and large orchestra, and Owen's war poems sung from the rear where there is also a fairly large chamber orchestra and children's choir.
I did get to hear the Dynaudio Consequence speakers at a Stereophile audio show at the Waldorf in New York in the late eighties, and got to meet the Dyanudio people. Prior to that it was all snail mail to Denmark. There was no Email then!
I did like the Consequence, but the sound stage was strange. There was the unmistakable feeling of the sound coming up though the floor! On mine there is a much more convincing concert hall presentation.
The Dynaudio Consequence is still on production but not advertised by Dynaudio, Last time I checked price was $70,000 per pair, but probably higher now.
I have always liked their speakers too, just not too many places that carry them these days. There's only one dealer in my entire area.
They do have authorized Internet dealers.
The local retailers have been disappearing for years and are not coming back, I don't think.
I agree for speaker shopping that is a major problem and contributes to decline of excellent home audio.
This is probably the best reason to learn to design and build you own speakers.
I think if I were to have to go speaker shopping now I would just get a table radio!
Things are not so bad in the top end if you stick with the few major players. In the big cities you won't have much trouble listening to the top end B & Ws for instance. For many other good manufacturers most will be out of luck finding an audition.
Alexandre
Alexandre
As a fan, former and current owner of Dynaudio speakers, I like this idea! The current pair I have is the Xeo 2 (their wireless, powered speakers). I wonder if they're going to have a way to integrate one of these subs wirelessly with the Xeo line of speakers… that'd be pretty awesome!
Alex.
PS: I used to own the Contour Special Edition bookshelf speakers.
