mayho
Time to make the wife mad!! Looking to upgrade the sub from a Klipsch RW8 to....
Room measures 3060 cf, with an opening of 7'2 x 3'6. I want it to feel it in my chest when watching movies, but music is my love. I want clean,clear,crisp,articulate bass. Been doing a lot of reading still need to ask the experts. Budget between 500-100. Thanks.
You may want to consult her first though.
A good sub to meet your need is not small. Hsu VTF3-Mk3, or an SVS sub come to mind up to $1k.
GlocksRock
GlocksRock
the 20-39 PC+ will be $899 + shipping, and it's got crazy bass, give it a look. I also hear good things about HSU, but have never heard one... those are suppossed to be a little better for music too, and will cost a bit less as well.
abboudc
B5I8 said:
Is it just me or is everyone going way over budget???
I assumed (as i'm sure others did) 500-100 was intended to be 500-1000.
That would seem to mean $500-1000, in which the HO-Turbo would be right there.
The 20-39 Plus is no slouch when it comes to music.
mayho
Thanks Guys! It should read $500-$1000. I have been looking at the HSU MK3, and the SVS pb12. They both look great but they also look large. Can I get awesome sound out of a "normal" enclosure?
Warpdrv
Warpdrv
In that price range you can look at the SVS PB-12 Plus, and if you check their b-stock you can get one for $850.
Im not crapping on the HSU, just shooting out info from what I know...
SVS is a great sub as well as the HSU...
Good luck... either of those choices will be awesome.. :)
