My speakers Rattle?
caleb211
Hey fellas, I just got my system as many of you know and upon hooking it up and watching across the universe bluray, I noticed that my left front speaker rattled. What could this come from? When I place my hand and apply just a bit of pressure to the inside bass radiator it will stop. It only rattles when there is heavy bass parts. Could someone please give me some advice/diagnosis. Thanks
bigred7078
bigred7078
perhaps something is loose? You could always pop it off and check. Otherwise since you just got it, i would take it back and get another one since it only happens to your left speaker.
braminator
braminator
I had a speaker do that once and it turned out the cabinet screws had loosened up. I tightend them all and the rattle went away.
