MacManNM said:
All I need to analize them is an impulse source, a digitizer, and a calibrated microphone. Which I have, and will perform measurements at a later time. These are prototypes, they are going to end up in the scrap heap in 6 months anyhow. Just a fun project for me to waste time and money, and have an excuse to drink beer and use power tools at the same time!
Unfortunately, it's no easy matter to measure/analyze audibility magnitude of enclosure wall resonances.
1. The majority of the output is on the sides and rear, which will be attenuated and hard to recognize in the front field response. In addition, the effective reflection distances in a normal environment will not allow for sufficient gate time for adequate frequency range analysis.
2. If you do full CSD analysis of multiple angles in fine increments from from front to rear, you will need a large turntable and you will need a true anechoic environment or mount the speaker suspended in the air with a sufficient distance from reflective surfaces, because in a normal set up, the gate time vs. frequency wavelength will not allow sufficient time window width to get proper resolution of the frequencies of about <1000-1500 Hz{1}. An even more accurate method would remove direct radiation of the driver all together, measuring only cabinet acoustic output, and this is possible, but adds great complexity to the situation. I can expand if requested.
-Chris
{1} If you shift resonances to a very high frequency, such as >1500Hz, then you can analyze them in a normal environment. This assumes an insanely rigid/high density cabinet; but to insure the cabinet resonance(s) are above the required range, an accelerometer must be used to measure the impulse response of the cabinet at multiple points.
