This is my ongoing review for the Marantz SR-6003 (EU).
Before starting the review, I just want you to know what type of user I am. This clearly affects my opinion and experience with the unit.
My user profile:
- I'm at ease with cryptic instructions and displays (love tinkering with the DCX2496's LCD screen, instead of using the software interface)
- I like to read manuals
- I like to tinker with the options until I get what I want
- I don't get along with "user simplified interfaces" because they annoy me by not letting me do what I want
- I prefer complexity and flexibility over simplicity and shortcommings
I'm a newcomer to hifi, keep that in mind.
I only had another receiver, the Yamaha RX-V861, currently powering 4 Tannoy Reveal 6 and one Reveal 66 in my home studio/ofice.
This is my second receiver and it's powering 2 Monitor Audio RS6, one RSLCR and 2 old sony bookshelves as temporary side speakers.
The rest of the setup is a 52" LCD screen, an EP30 HD-DVD player and a PS2 (my wife loves playing DDR).
My room has 6.8m x 3.9m x 2.7m (in feet= 22.3 x 12.8 x 8.9). Running it through a room modes calculator (
http://www.bobgolds.com/Mode/RoomModes.htm) showed good results.
Have some pics:
Check the specs
here
Aesthetics and layout
To me, this thing is a beauty, with the closed front lid you can only see two big round buttons (input and volume) and one smaller (power). I don't use them, but they're nice. To open the lid you have to press it's bottom, which is not easy to do. I expect it to be very hard for my daughter to open it (3 weeks old).
The LCD is crisp and the led segments are white. Really nice. You can cycle through normal display, display with a big volume level indicator or with the display off. In display off mode, there's a very little logo indicating the display is off. Makes no sense until you realize you need to have a clear indicator that the unit is on.
A very cool thing about the power button is that it will only turn the unit on if this button was used to power it off. If you used the remote to turn it off, the button won't work. To get around this you'll have to open the lid and press the enter button. This could be a very good small child-proof device.
The back of the unit seems to be well layed out. The 3/2 HDMI I/Os are on top and upside down. The digital sound inputs are all together at the center. You have 3 optical inputs and 2 coaxial. Each of them has a number (Digital 1,2,3 (opticals) and 4,5 (coaxials). Note this down when setting the connections. You'll need to know them when configuring the inputs on the input selection menu.
It has a 150W outlet. It can easily power some fans, hdmi switchers, equalizers, etc.. The plastic plug covering it was very hard to get off! I had to really wank it.
The speaker binding pairs (+-) posts seem to spaced according to standards, meaning it's possible to use those double bananas, one for each +- pair. I have to confirm this, but my yamaha implemented this spacing between adjacent channels. I nice touch is the protective film that covers the binding posts area. It helps prevent shortcuts between the post and the chassis.
It has a lot of other inputs that I don't use, so, I won't comment about that.
Initial Installation
Plug the bananas, connect the optical and coaxial cable (making notes on the input numbers), connect HDMI I/Os, and turn it on.
The OSD (tested through HDMI) is simple to navigate and to configure. The output is the #1 by default.
I proceeded to turn off the surround back speakers and the subwoofer. Then I went into the Audissey setup and made the 6 measurements. It took a while to calculate but everything went fine. The distances were spot on. The calculated flat EQ was almost flat, probably due to the nice integration between the room dimensions, speaker placement and speaker response.
I can't comment yet on the sound and the effect the EQ has. Later on I'll measure my room with REW, with and without Audissey. I'll post some graphs.
Source input assigment
I'm very impressed with this one. For a geekish guy like me, to have a input assignment matrix and be able to tweak it to my needs is very neat. The best part is that the sound is not interrupted, this alone helped me to figure out what number corresponded to the current input. As an example, I was trying to find what was the number of the coaxial input connected to the cable box's coaxial audio output. I set the input to DSS and then entered setup, after that I just had to keep changing the digital inputs on the DSS line, until the sound came through.
Making all the sound inputs correspond to the device inputs on the remote was a breeze.
I also took the opportunity to rename the inputs, it was very easy with the displayed keyboard.
Remote
The remote is good looking, easy to work with, but has a few niggles. First the ergonomics. While it is very confortable to have in the hand, there's really no clear back/front distinction. I found myself holding it backwards a few times, until I realized that the light button should always be on the right side.
Which takes me to the remote light. I wonder when will manufacturers realize that having the keys glow is nice, but totally useless when you want to read the labels below the keys. In fact, with the remote light on it's even harder to read them.
The way of working with the remote could be a hassle for some and a real treat for others. To change input sources you have to press the corresponding source key twice. this may seem stupid, until you program the remote to control all your sources. Then it makes sense. You press the source key to make the remote control the corresponding unit and press it twice to make it the current source. What this means is that you can control any source without interrupting whatever you're seing and listening. The remote can also store macros to facilitate your most common activities. For example: change remote to TV -> turn on TV -> change TV input to receiver HDMI -> change source input to DVD (double press DVD) -> turn on DVD -> wait 10 seconds and press play. Macros can hold 10 key presses.
Some will not like having to press the source inputs twice just to change the current input, but the added funcionality is a real bonus to me. The Harmony 555 might be better, but I havent decided yet. At least the 6003's remote does not need to connect to the internet to make any adjustments!
USB input
It works but it's far from perfect. It reads mp3, wav, wma, aac, but no flac. It can read FAT32 formated usb disks (not compatible with NTFS). It will display files and folders sorted by the order they were created on the disk (remember this when filling your disks, the first folders to copy will be on top). It has no display sort, but when actually playing the files, always plays them in alphabetical order. When a folder is finished playing it jumps to the next folder (unless repeat is on). It will display the name of the artist and track being played on the LCD and you can navigate folders using it, but the OSD is much better suited for this.
The only negative point on USB mode is that marantz forgot to use audio buffers. When you navigate and leave the folder that's playing it stops. What the hell? You can navigate the current folder but can't go to another folder? Maybe a firmware can solve this.
Anyway, it works and if you have your collection sorted in music styles folders (electronica, country, classical, etc) it's very easy to just choose a style, enter the first folder, select the first track and just lay it there playing all the folders in order. M-DAX processes the sound on the low quality files and makes a good improvement on the perceived quality. It sounds very good to me, try it to see if you like it.
Radio Tuner
Normally I wouldn't even mention this, but the receiver's tuner is very good, even with the short FM cable antena suplied. I'm pleasently surprise by this and will start listening to radio once more. Again, the M-DAX thing is really helpfull to get a better sound.
HDMI handshakes
I have my DVD playing a multi channel disc and I turn off my TV (I don't want to look at the pretty pictures or the orchestra playing), for a few seconds the sound is interrupted. The same thing happens when I turn on my TV again. I guess this happens with most (if not all) receivers. I'm glad many disc start playing immediately or the play option is pre-selected making it easy to leave the TV off.
My impressions so far
- a joy to use and looks great off or on (the display is very nice and very usefull).
- very easy to setup and configure (the input matrix - Function Input Setup - is great!).
- very capable remote, switching between source control or input is very easy.
- USB works, but could be improved
- having 3 optical inputs and 2 coaxial is just perfect for my needs
- radio works flawlessly, excellent FM reception
- M-DAX really works for radio and MP3s
I'll be back soon.
