My new CLR3000 Center
Midcow2
Midcow2
Here of some pictures of my Den HT after I added a new CLR3000. I had orignally built a shelf above the TV for my other center speaker. When I got the Defintive Technology CLR3000 is was so heavy (I think 55 lbs) that it was bowing my shelf and partially resting on the TV; NOT GOOD. I built a 2x4 brace and everything is perfect now. The brace doesn't show, but I stained it mahogony anyway!
I love the CLR centenr channel. I was already to go AV123 Rockets and Bigfoot and replace my older Def Techs. Then after much learning and discussion on this forum ( Thank you AcuDefTechGuy and others) I found out that Def Tech was at least an equal if not a better speaker line. So I upgraded my Def Tech to the next level from BP2006s and ProCenter100 to BP7002s and CLR3000. WOW! ;) WOW! ;) is all I can say.
