Thanks for the heads up Phil. It sounds like you'd recommend Sony over Polk in general? I did see some good sales coming up for klipsch as well but it seems like the same speaker in terms of specs is almost double the Polk. Worth it?
For everyone, am I better off spending my money on two nicer floor standing speakers with no center for the next six months to a year. Or get smaller floor standing speakers plus a center channel?
What about the sub? Do I definitely need the 12" or will a 10" be sufficient?
Tucker, Polk makes a lot of different speakers. The ones that you are considering are decent at best for home theater, but not very good with music. The tweeter is known to be very harsh and bright sounding even at moderate volume levels. Hence, the Polks can become very fatiguing rather quickly. As such, I would look at other options in your price range.
You mention that you are about 50/50 music/HT. Therefore, I would take a closer look at both the Sony Cores and/or the Klipsch that will be on sale at your local Best Buy on Black Friday. It would be a very good idea to go there before the sale and listen to both the Klipsch and/or the Sony Cores. That way, YOU can decide for YOURSELF what sounds best. We can guide you, but the bottom line comes down to what YOU prefer.
We also need more info in order to help you better. What size is your room? How far will the sweet spot be from the front-stage? What is the layout of your room? Having a sub will make a significant difference in your setup. Maybe it is a good idea to get your fronts and a sub first. Then, expand from there.
For HT purposes, the center channel is the most important speaker in your setup. As such, you need a center that allows for very clear dialogue. The front speakers really need to be matching if possible. Whatever you do, stay away from Polk subs! Anyways, give us a bit more info and we will be glad to help you. Sorry just now getting back to you but Kentucky was playing Michigan State and I am a BIG Blue fan! BTW, KY won too!
Cheers,
Phil
