My First DIY Project: Slopzilla subwoofer completed, a tome by Greg
bcycle
Greetings!
I know you all have all been waiting with BAITED BREATH to hear about progress with my DIY Subwoofer (aka Slopzilla). For those who haven't been paying rapt attention to previous postings on this project my goal was to build a DIY sub to complement my music/home theater setup that would meet the following parameters:
Cost: around $200.00
Produce reasonably clean uncolored sound for both music and movies.
Not too big; 4 sq. ft was my max size.
Bass below 25hz.
Play fairly loud.
After some research I ended up with the woofer, amp and some miscellaneous parts from Parts Express and bought the lumber and hardware locally. I did run $107.00 over budget due to the fact that I decided to upgrade to slightly better parts. Here's my parts list and dollars spent
The Parts:
DAYTON RSS315HF-4 12" HIGH FIDELITY SUBWOOFER $104.00
DAYTON SA240 240W SUBWOOFER AMPLIFIER..Amp 110.00
1 sheet MDF 4'x8' x1" 35.00
Egg Crate foam 20.00
Gasket Tape, screws, grill cloth, etc. 22.00
Black Paint and Primer 16.00
______________________________________________________________________
Total $307.00
Some Background:
The reason I dubbed the project "Slopzilla" is because I am NOT a craftsman by any stretch. I expected dents and drips and mistakes that would yield an unsightly appearance and anticipated that despite my goal for clean bass, this thing could end up a boomy, sonically uncontrolled piece of furniture. My expectations were also low since I don't know acoustical theory all that well. I relied on a lot of reading and research to help me get by but I had low expectations. The "Zilla" part is due to the fact that even though my goal was something relatively small, it's still pretty damn big.
The Design:
Since my craftsmanship is suspect and my budget low, I decided to make a the box very heavy (1 inch mdf) to compensate for my inability to create complex bracing, mitered joints and other elements that help stiffen and neutralize the sound of the box. I ran some numbers using some BassBox Pro to resolve shape and size and came up with the following.
Qms = 3
Vas = 3 cu.ft
Fb = 19.82 Hz
QL = 6.506
F3 = 18.93 Hz
Dimensions: about 16"w x 25"H x 26"D
SCHEDULE
Day 1:
Cut Wood
Make Holes
Put box together with screws n' glue. Clamped and let dry overnight
Day 2:
Silicone caulked all interior joints
Primed and Painted
Added egg crate foam
Mounted amp, woofer and port
HOW"S IT SOUND?
Movies:
I made my neighbor Rich help me lug this thing up to my "Man Room" on the 3rd floor. It seems to weigh about 100lbs, but the Dayton Driver and 1 inch mdf can do that I guess. I set it up to the right of my stereo and connected it to the receiver's sub output. First listen was with the new James Bond Casino Royal and I gotta say, it sounded pretty damn good. My neighbor Todd, (the movie geek with the projection home theater) said that he was "amazed at the sound". That it "made the hair stand up on the back of his neck" He said he was "jealous" and his manhood "diminished". I think this was a compliment. My impressions with movies; The woofer seemed to woof at the right times (explosions, loud parts, etc.) but it wasn't boomy or there when t wasn't supposed to be. The more I listened the happier I was.
Music
The next big test would be with music but I was disappointed to learn that the Sub-output on the Yamaha does not send a signal to the speaker in non-surround recordings while in "Pure Direct" mode. Pure Direct is my Yamaha's method of sending the signal through the cleanest path without signal processing and it actually sounds quite good. Even pre- sub I would get rock stable imaging and fairly neutral mids and highs and the bottom end was clean and tight (down to about 40hz) I like the Pure Direct. So the next question was, will I be able to enjoy the sub with with music while in Pure Direct Mode? I posted to Audioholics and received some very useful and helpful input from j_garcia about hookup possibilities. In the end I ran the pre-outs and the sub outs of the receiver to a line level a/b box. This allowed me to use the sub-output while in a surround mode yet switch to the pre-outs for listening to music.But, since I was not running the music throgh the sub's xover I was concerned there would be a doubling of the bass in the 40hz range between my A/D/S M9/90's (where the upper end of the sub met the bottom end of my speakers). I listened to a bunch of cds and there did seem to be a "hump" in the bottom end with a lot of the music. I posted to Audioholics and again got some great help (thanks Mtrycrafts, MDS, AVRat, and j_garcia). I ended up moving the Sub and angling it. I pulled my main speakers about 6" inches closer towards my listening area (so they're about 3 feet from the back wall) and voila(!), everything fell in place. The bottom end became very smooth and seamless. Tight where the music warranted and very low if the data was there. I was really surprised to be able to hear much more room ambiance in a lot of my CD's (the new White Stripes for example) which I did not get during my pre-sub days. Also, the imaging and mids of my main speakers improved a touch, possibly the result of moving the main speakers further from the back wall. Finally, I don't think I've come anywhere close to testing the limits of the 240 watt amp and it get's very loud in my 25x25 sq ft space with cathedral ceilings.
EPILOGUE
So, here am patting myself on the back! I think as far as DIY projects go, building a sub was a no-brainer. Fairly simple construction and not too much rocket science can yield a pretty nice end product. I have learned that the cost/yield benefit to a high quality DIY sub is easier to pull off for a layman like me than if I were to attempt to build some decent speakers.
Thanks again to everyone for all your help!
Greg
Notes and Background: In my previous life, long ago I used to sell stereos. Not super hi end, but regular high end. (B&W's -801, etc., Quad, Revox, B&O, Rotel, Bryston, etc.) I don't know electronics or sound theory but as the result of listening to good stuff, I developed a pretty decent ear. I learned there's a lot of wiggle room even in mid-fi and if the setup doesn't sound right at the get go, one can always tune things up with by matching the components, better cables, speaker wire, placement etc. (You will not find me applying drops of fluid to my speaker connections or coloring the edges of my cds green ).
annunaki
annunaki
Moderator
Nice job. It is good to hear someone with a fairly discerning ear give this sub the thumbs up.
Adam
Adam
Nicely done! Thanks for sharing the photos and details with us.
bigbangtheory
Well damn, I was hoping to see pics of a green reptile-like beast that had the sonic qualities of godzilla!
In all seriousness, kudos to you for taking on this task, and thanks for sharing. It gives the rest of us hope when we look in our wallets and see that we're a few hundred dollars short of buying the sub of our dreams from ______ retailer.:eek:
F
fmw
Congratulations. You can enjoy both pride of ownership and pride of craftsmanship. Good work.
