avaserfi
avaserfi
I got a few PM's today about my DIY traps today and I figured since they are so easy to make I figured I would post a few pics on what I did with pictures to help whoever wants to make some out.
First off find someone who will sell you OC703 or OC705, keep in mind the latter will be more absorptive, it is generally sold in sheets that are 4'x2'x2" or 1" thick sheets. One note: be sure to always wear gloves and if you can a mask with the fiberglass for your protection. I used 2" thick sections for reflection absorption and 4" thickness for corner straddling to help the low end. With this build you can save yourself money and get added benefit by making the frame a little deeper than the used material. This allows some waves to go through the dampening material then reflect off the wall to be absorbed by the back side of the dampening effectively doubling the working size of your dampening material. Because of this the reflective portions of my panels where a total of 4" thick and the bass traps were 6" thick. If you don't want your frames sitting that far off the wall you don't have to do this.
The first thing you need to do is decide on the size of panels you want to have. I went with a variety of sizes. The easiest way to do this would be use the original 2'x4' sheets, but if you want to cut the material be sure to wear a mask and I would recommend using a serrated knife with a guide on each side so you cut straight.
Here are my cut pieces:
As you can see there is also a frame for one of the bass traps in this picture. First what I did was glue to pieces of OC705 together using 3m spray glue. After that I made the frame while the fiberglass dried. I made the frames slightly smaller than the cuts of fiberglass to ensure that the fiberglass would not sag or slide out accidentally.
When making the frame just but some 1"x4' planks and cut to size. If you do not have a saw your local hardware store will likely make cuts for you at a minimal price. Although, if you are more handy you can do what I did and buy a sheet of plywood and cut the pieces to size which will cost less, but be considerable more work. To get a clean look I used countersinks to hide the screw holes. I used two screws per corner and filled with a liberal amount of wood glue before tightening with a drill. While this frame doesn't look sturdy it is very much so and I haven't had a problem with them at all.
To get the fiberglass in the frame I needed to coerce the fiberglass in without breaking it too much to do this I wrapped a corner in plastic wrap and used the plastic as 'lubricant' to get the OC705 in easily:
Once you have your fiberglass in the frames all that is left is covering them with cloth. All you will need for this is a staple gun and cloth. When picking your cloth out I would recommend going to your local fabric store and buying a fabric that you can breathe through easily. If you feel your breath, fairly undisturbed, it should allow sound waves through as well.
Cut the fabric larger than the face including the sides of the frame and some of the back as well. It is far easier to cut a larger piece than a smaller one when stretching fabric.
To start out ensure the piece of fabric is large enough and then put one staple on the back center of one part of the frame. Stretching the fabric evenly to the opposing side put a staple there. Then do the same with both other sides of the frame. After this slowly staple outwards evenly on all sides trying to keep the fabric stretched evenly all around.
In the following picture I started with the top portion and stapled center then went to the bottom stapled center. After that I put a staple in the center of each side and then started over adding a two or three staples per side always going to alternating sides and ensuring that there were no wrinkles in the fabric.
Some of the finished pieces:
The only blemish you can find on these which can be fixed by more careful folding of the cloth:
To hang these I bought eye-hole screws and screwed them in the back using picture wire between them. After that I used a heavy weight picture hook to hang these followed by foam on parts that touched the wall if I felt decoupling was needed.
If you have any questions feel free to ask here or PM me.
Edit: For more information on acoustics I can recommend this website link or this book.
mazersteven
mazersteven
Looks like outstanding craftsmanship. Good Job :D
Thanks for Posting.
Tomorrow
Tomorrow
Wow, wow, wow! Thanks, Andrew!! :)
Now...when are you coming over to do the work? ;)
avaserfi
avaserfi
Hah, well I was planning on visiting my sister who lives pretty close to you, but I don't know how motivated I would be to work when she stuffs me full of chefly delights!
It really isn't hard though, I promise. I made nearly twenty traps the hard way, by cutting all my wood from a board of ply, and it took me one day to make everything! Don't be worried, just let the wife pick the fabric to help with WAF.
Seth=L
Seth=L
Very nice look panels. When you get a chance post your thoughts on the effect they have on your sound.:)
mike c
mike c
thanks for the step by step. this will help me a lot.
although, you coming over to build them for me would help me a lot more :)
I already have the wood pieces, guntacker, cloth ... all except the FG.
Dolby CP-200
Looks like it cost you half of the cost to make and there’s nothing to it, just a little patience and perseverance.
Glenn Kuras
Glenn Kuras
GREAT JOB :):)
Keep us posted on how the room sounds.
Glenn
avaserfi
avaserfi
Ahh, I knew I forgot something when I wrote this what they did! :)
When I set out to build these it was because my bass was way too boomy and I knew it was the room, not the sub because certain points in my room (corners) were 10dB hotter than others. Also, I wanted to remove reflections because I noticed distortion caused by this especially during movie dialog, but also with complicated music.
After putting the panels up I have far better imaging and there is never a point in time where reflections cause confusion over dialog so my reflections have diminished greatly. Also, my bass is tamed it no longer seems to take as long to decay in the room. My speakers also seem to be more detailed. I attribute this to less reflections 'confusing' my ears with multiple instances of the same information. All in all I am extremely happy with these panels. I had read how much treatments can do for sound quality and set out on this project, now I know exactly why people say treatments are as important as speakers. It was like I got a whole new set of speakers when I put these panels up thats how much better it sounds.
Adam
Adam
Excellent job, Andrew.
DIY acoustic panels, DIY speakers. All that while working and going for 24 (I think) credits at school. I can't wait for your articles next year when you have the year off. I am eagerly anticipating the DIY Plasma Display constructed out of a regular double-pane window, window screen, PC power cord, and neon. I'm missing some stuff, I know...but you'll fill in the holes. :)
crashkelly
crashkelly
avaserfi,
Excellent job. I think I will have to tackle some of those after I get my HT renos done.
Thanks much for the detailed post and instructions
Cheers
Michael
WOOHOO Post number 100. I am now a Seasoned Member. Wonder if it is oregano or sage :D
WmAx
WmAx
8# mineral wool fiber board is as effective as OC705, and it available at a far lower cost.(1/3 to 1/4 the cost of OC705)
-Chris
avaserfi
avaserfi
-Chris
Good point. I didn't really have to worry about getting the fiberglass as it was a gift, but when I called around for quotes I got anywhere from $2.00-$3.50 per square foot.
Perhaps when I add more traps I will use 8# mineral wool instead since I think I will be buying the dampening material next time.
WmAx
WmAx
Locally, the 8# mineral board in 2" thickness costs me about $0.77 per square foot.
-Chris
John N
Wow ,those look like my GIK panels.
Do you have any pictures of how you made the folds? I'd like to change the color of my GIK panels and make some 24x24 " panels.
John
avaserfi
avaserfi
John
While I don't have pictures of me making the folds (hands were full) I just took some pictures of the folds and will try to describe the process.
First the pictures:
You will need to allow extra room on one side near the corner, so don't staple too far up. I had to take a couple staples out on the first one. Start out by lifting the cloth on the side with more slack up, by the corner away from the panel and allowing the fabric to fall in between the lifted part and the panel itself. After just wrap the piece you are holding up along the corner as seen in the pictures. To make the seam as invisible as possible try and keep the seam along the edge.
I wish I could have taken pictures as my description is not great, but I promise it isn't too hard when you get to it! Let me know if you need more clarification.
pdxmonkeyboy
where did you place the traps? Is there any standard rules to follow?
Thanks,
B.
avaserfi
avaserfi
Thanks,
B.
While there are some general rules to follow with placement some things are more important to treat than others depending on your room. If you would like suggestions on treatments I would suggest starting a thread with your gear and your room layout in this section of the forum and many people will help :).
