My Denon AVR is not passing 4k resolution.
Sometimes hdmi can be fussy about sequence....display then avr then source sometimes is better for example....
cameron paterson
Well I do that. It wont work that way. I just went straight to the BD player to see if it was getting video. But no sound that way so I cant leave it that way.
KEW
KEW
What do you mean power on sequence? Leemix: what did you want me to do with the video on the receiver 4k signal format? Can you walk me through it?
Check setup-video-4k signal format
*on the Denon
I can't check my Denon to make sure (not home), but I believe if you go into the setup menu on the Denon you will see setup, from there choose video, then select 4k signal format and see what the setting is.
cameron paterson
The setting is standard.
cameron paterson
I just checked with both HDMI cables and when i go straight to the BD player from the PJ it says 4k/30p... Why wouldnt it say 60p?
cameron paterson
Maybe thats why its not working? Its not giving full 60p?
L
Leemix
Have you checked the specifications of the projector to see what video modes it can handle?
L
Leemix
Try with a real 4k UHD blu-ray disc and see.
bommai
I have the denon 4300h and never had trouble with it. I am using a epson 5040ub and don’t x800. I also have an Apple TV 4K. All of these work great. Make sure you are connecting the zone 1 primary video output to the projector. Zone 2 does not support 4K.
X800 make sure you are connecting hdmi 1 to the denon.
Make sure you connect to a 4K capable hdmi only in the projector.
Sent from my iPhone using Tapatalk Pro
cameron paterson
Yup i have done all those things. Thank you.
cameron paterson
Do you guys mean HDMI pass through? set on or off?
cameron paterson
Didnt work on or off. Gotta be the projectors HDCP 2.2 HDMI is messed up!
I don’t use a Denon anymore for my HT Room, So it might be HDMI pass through. But I recall there was a VIDEO SETUP section that deals with resolution CONVERSION.
I know on my Yamaha there are setups for an AUDIO section and VIDEO section.
Might also be HDMI compatibility/handshake issue with the Denon.
Is it feasible to “borrow” the cheapest Yamaha 4K AVR to test with your PJ?
cameron paterson
Thats a good idea to borrow the Yamaha but dont have cash right now.
