As I mentioned before, I am converting my game room into a music listening room. I will be adding a 75" TV, but I already have a media room, so I do not want / need surround speakers. But I really wanted a good center speaker, and I have decided on the Klipsch Heritage Heresy III - three of them, one for a center speaker. My daughter (brilliant young architect - yes, I am biased) is helping me design, and using a Heresy III as a center speaker adds difficulty to coming up with the simple, elegant, uncluttered look I am going for, with a 70's feel.
I have about 300 old albums I look forward to listening to after a near 30 year rest from the needle, but I also have a wide taste in music genres and will be listening to digital music, too. Now I need to come up with the other components I will need, and this is where I will need your advice. I have decided to bypass the expensive tube route, but I want something to give me the warmer sound I am looking for, to compliment the Heresy IIIs. I know preamps are loved by many, especially when a turntable is part if the system, but I would prefer one big fat unit that does the work of the preamp and the amp, if that exists. I need advice on this topic.
I will be using DirecTV, so that box will be part off the system - I assume a surge protector will be needed (like I have for my media room). Also, I would like to play DVDs. Here is a scale photo of what I sketched out on a computer - the square grids are one foot each. Forgive me, I am an engineer, not an artist. The blue boxes will be speaker stands. On the left and right, I might replace the stands with a pair of subwoofers if I decide down the road that I want them - not sure that I will, so I am going to try it without them first. I will tilt the center speaker up a bit.
I saw some really cool modular, made-to-order stackable component trays, so I just copied a few for this layout - I will let my daughter help me make the final pick on these. My biggest problem with this is that the turntable, the only component not operable by a remote, might be a little low for an aging fellow with minor back problems. Any tips or advice on this overall design would be appreciated.
I will be seated couch high, maybe with reclining seats. I do not like high TV sets, but I would like to raise it higher than shown here, and angle it down to the viewer a bit. I really need advice on TV height, as I would like it higher to make the component modules higher with a higher turntable.
I am open to suggestions! I think I will really like the three Heresy IIIs!
