My Bedroom System
  • Thread starter Thread starter nm2285
N
nm2285
712
0
18
I'm a college student who must leave his main equipment at home for far too many months of the year. This is the good stuff. At school, I have some older, cheaper equipment since I figure it'll get abused more often.
The speakers:
It's a DIY 2-way design using the Peerless 850122 and the Vifa XT19. It's a 2nd order linkwitz-rielley crossover at 3000Hz. I originally had a 4th order in there, but had to rebuild them. The 4th order I think did a slightly better job, but the 2nd is still really quite good. The boxes are sealed with 3/4" MDF all around with 1 internal cross brace. The finish is a gloss-black baffle, red oak veneer on the sides (which is stained a combo of cherry and red mahogany), and flat black rear. There are a few spots that just need slight touchup paint, but I let them go for later so I could actually use them at the end of break.
The furniture:
I also designed and built the stands and the racks and tv stand. In the stands, MDF is used for the shelf and base, red oak stained the same color as the speaker veneer for the "legs", and there's 1 PVC pipe filled with sand to add weight and 1 empty one for cable organization.
The rack and tv stand use MDF for the shelves, 3/8" all thread rods for the shelf legs, and cedar for the TV stand legs (stained cherry to closely match the red oak staining). The shelves are cut at an angle so reaching behind to mess with cables is easy.
The rest:
TV - Sony KV-27HS420 27" HDTV
DishNetwork DISH811 HD receiver
Panasonic DVD-RP56 DVD player
NAD C370 Integrated Amp
Adcom GTP-500 Preamp (used only for tuner and phono preamp)
Yamaha CDC-585 5-disc CD changer
Sony tape deck
Technics SL-1600MKII turntable
D-Link DSM-320 digital media streamer (not shown)
Behringer DSP1124P Feedback Destroyer (as parametric EQ)
Pinnacle DigitalSub 350 (in left corner of the room)
Panamax SurgeProtector8 DBS+2
Cables are a mishmash of Acoustic Research, Monster (I don't buy them anymore), and DIYs.
Not bad for a college student
Much nicer than what I had when I was in college!
So what are you studying?
Thanks for the compliments.
As for studies, well, I study a lot of things...my major is civil engineering but i'm pre-dental and have minors in chemistry and engineering/business.
Nice Set-up! How do you like the Pinnacle Subwoofer? I have seen Pinnacle ads and I am kind of curious how they perform.
Its alright. It's musical and reaches pretty low. However, its has an isobaric conformation (1 12" driver directly behind the other). This causes some distortion at higher levels - like a chuffing or something, i can't really explain it. Its great at low to med to even pretty high levels. BUt at some frequencies at high SPLs, I'd prefer something else. I bought it 2 years ago for $450 when its retail was $1200, so it was worth it to me. I'll build my own eventually to replace it.
