My 12.5ft^3 AV15-X project
VERTIGGO
VERTIGGO
I've been lurking here learning for a while and I'm finally putting my plans to use. I chose an AV15-X from Acoustic Elegance and I already have an EP2500 and a BFD1124 ready. This is for a home theater so I went big and plan to tune at 19-22hz. The ports will be two 6"id PVC pipes and I'll add a wood face to the box to flush mount the driver and flare the ports a bit. Here's my work so far:
I ordered a router jig but actually found my saber sawing to be plenty good enough for the internals (impatience is a killer).
I read that a rule of thumb for bracing is to eliminate any area of more than 144"^2, so I added some small pieces to split the large sections of MDF.
I have internal dimensions of 19.5"W, 28.5"H, and 38.25"L which is the "golden" rule. I calculated my effective volume (considering a driver and ports) at 22041"^3 and my two ports are currently at 20.5" each which should give me a 21.67Hz tune. My plan is to tack it together and run a rough test before sealing everything with silicone since I have room to swap out for ~28" ports (~19Hz). I also need to decide on dampening material if it's necessary... any thoughts?
VERTIGGO
VERTIGGO
I got some 6lb. carpet padding for the inside since I'm at a loss as to what else to use... will that be plenty absorbant for any errant high freqs I have to deal with?
brybo86
Av15-x
I'm beginning a project similar to your with the AV15-X
Whenever I try and put the parameters into WINISD it give me an error. Could you send me the winisd file with the parameters already in place? it is a vented enclosure.
The newest winisd pro
Thanks,
-Bryan
MidnightSensi
MidnightSensi
Cool! Thanks for posting pictures, keep us updated.
Where are you going to get 6" PVC pipe? Any reason you went with two round ports rather than a slot port?
Dampening material you can use rockwool.
Shock
Shock
If I know anything about physics....and I don't, rounded ports should allow for less air turbulance on the edges of the ports.
P.S. You should stuff it with ShamWoW's
