Sheep
Sheep
Hello yall'
I was down at my old high school today to get some pictures of the Drag Car I worked on, and figured I'd share it with you.
Also, if you have any pictures of muscle cars you've seen (IE: NOT from the internet) please, feel free to share.
The car is a 1969 Camaro. The motor is a 5.9 liter (360) with a 4bbl carb (don't know make or CFM; didn't install it) with some upgraded heads (again, don't know the make) with hooker headers, and an edlebrock riser intake manifold. It has an MSD separate coil ingintion system with a delay/advance timings box in the cab. The Hooker headers connect to an H pipe which is then connected to dumped Flow master 40 series mufflers. It turns out about 450hp, and with the new slicks can run mid to low 11s quarter mile times.
SheepStar
majorloser
majorloser
Moderator
Ain't that...
a bit far North for the ol' Stars and Bars? :confused:
V
VS540
A friend of mine has a 1969 Camaro Z-28 with all original parts.
Another friend has a fully rebuilt/restored 67' Mustang Fastback.
Rock&Roll Ninja
Rock&Roll Ninja
My last car was a '72 Plymouth Duster w/ 383 (overbored to 397) big block.
It worked really well for about three weeks..... but then the brakes stopped working, the fuel gauge wasn't hooked up, there were no reverse lights, it got about 6 mpg.......
Now I drive a regular car (that starts every time I want it to) and I couldn't be happier. If I want to go fast again I'll buy another motorcycle.... but thats another thread.
Sorry, can't find any pictures right now.
N
Nick250
I grew up in the heyday of muscle cars in the 1960s. The only one I actually drove was a friend's Chevelle SS 396 with a 4:10 rear and high compression option. On the curvy back roads out in the country where we lived it was scary fast. Can you say "understear"? Yikes!
Nick
Sheep
Sheep
Nick
Err, Front wheel drive cars understeer (when you turn, you keep moving straight). You're thinking of oversteer (when you turn, you turn too much).
SheepStar
N
Nick250
SheepStar
Sheep, which end the drive wheels are on is not much of a contributing factor for understeer vs. oversteer. Where the weight mass of the car is located is the biggest contributing factor. All things being equel, most front engined cars will tend to understear and most rear engine cars will tend to overstear because of where the weight mass is located. Mid engine cars have the most neutral handling and for me the most fun to drive quickly through the twisties. It is a bit easier to build in neutral handling in a front engine, rear drive car because the front wheels don't have do as much work, but there is only so much you can do with all the weight up front. Just about all American cars made in the 1960s understeared as they still do now, though the modern cars understear less now becasue of improvements in suspension design. The imports understear now as well, but less so back then because a lot more of them were rear engined and therefore more likely to overstear. Examples, VW Bug, Corvair, Porsche.
Now, if you took a 1960s muscle car and had the balls to toss it into a turn sideways at a high rate of speed and then punched it, some very exciting power overstear would be the result. It was kinda drifting, before drifting existed.
Regards, Nick
Sheep
Sheep
Regards, Nick
While I agree with your above post, traction, and weight over the wheels are the biggest factors in over/understeer. I'll also argue that a rear drive(front engine) car is easier to ballance then a front drive(front engine) car.
From now on, front engine, front drive cars will be FF.
Front engine, Rear drive cars will be FR.
MR is... you guessed it, mid engine, rear drive. :D
Then porsche, and corvairs can be RR.
Example: A FF car has an engine, transmission, and most of the electronic parts of the car, on the front half of the car. The only significant weight on the rear tires is the gas tank. To make the car balanced, you have to over-design the layout of the heavier parts so some are in the back half. My friends BMW has the battery in the trunk so it can have a 50/50 balance(BTW, its a FR car).
In a rear drive car, you have the engine and the bulk of the electroncis over the front wheels, while the gas tank and drivetrain remain in the back half. That gives a FR car a significant advantage in balance, and requires less enginieering in a balance perspective. Thusly making them more suseptible to oversteer due to traction "issues" (see: heavy foot) then weight issues, or understeer at all.
Also, traction. Most 1960s cars were not balanced. Because the front tires had most of the weight, they simply spun the tires going around a turn (if they had sufficient power, which some had in spades). A ff car will over steer only because of a weight issue, but that only happens at significant speeds, and it has to be quite a turn(or a traction issue from poor design/improper maintanence). FF cars have a significant amount of weight over the tires, and would require copious amounts of power/extremely poor traction to spin the tires creating understeer. I am willing to say that a FR car would rather oversteer then udersteer.
Porsche cars (the RR ones) suffered from oversteer simply because of the weight. They didn't need to spin the tires, or go extremely fast(we agree on this, just getting it out there).
Corvairs are death traps. :D
Good talk,
SheepStar
hemiram
hemiram
My friends dad "drove" a Corsair in WWII, never complained about over or understeer, just those pesky Japanese Zeros and bullets that chased him all over the Pacific ocean..:D
hemiram
hemiram
Almost all factory cars understeer, slightly or severely, partly because of safety factors, and partly due to simple physics and tire size/grip.
A Porshe 911 is pretty much neutral as it can be, and combined with a near 50/50 weight distribution, and decent or better power, and on top of it, a short wheelbase, is a very easy car to spin, and a number of people have crashed them due to this ability, useful if you know what you are doing, sometimes deadly if you don't.
N
Nick250
The new 911s are 50/50? I would have guessed something like 40/60. Anyway I had a fair amount of wheel time in Porsche 911T in 1969. On those older 911s if you realised you were too hot in a turn, against your natural instinct you had to keep your foot planted on the gas and try to steer your way through the turn. That was your only hope of not crashing. If you lifted, the it reduced down force to the rear wheels and the car would spin like a top. It only happened to me once, no damage done and a lesson of 911 dynamics. Scared the crap out of me too. The new 911s have oversteer dialed out with bigger tires in the back and modern suspension design. To this day, that 911 was the most fun to drive that I have experienced.
Nick
mustang_steve
I'm more of a GN fanatic myself.
This shot is from the internet just because they all look alike...at least when they are trimmed out as they are supposed to be, black and beautiful.
Ax-man
Ax-man
Then porsche, and corsairs can be RR.
Corsair ...
Corvair ...
I drove a Corvair early in high school then stepped up to a Pinto station wagon ... I was stylin'. :D
E
echo
camaro?
that nissan maxima in the back ground up on the hoist in your schools shop is pure hawtness!
Sheep
Sheep
Heh, yeah. Those are mostly doner cars, or kids cars.
Don't worry, that Maxima will have spinners, and a big fart tip so it can be leet.
SheepStar
snatchss454
I own a 72 chevelle 454 SS(clone). Nothing like old American Iron. Here she is:
