multiple speakers (11.2) setup configuration
Hampton
I need some advice on how to wire a system for an 11.2 configuration. The reason for this many speakers is the following. I have a home theater I'm building (DIY) and this room has a balcony (i.e 2 floors).
I am going with the typical 7.1 configuration only now I will be adding 2 subs instead of one but in addition I will be adding 4 more speakers at a higher level to accomodate the balcony level. So there will be 2 speakers for the LS, 2 speakers for the RS, 2 speakers for the LrearS, 2 speakers for the RrearS, and the usual LCR speakers which gives me a total of 11 speakers.
My question is in regards to what I hook these speakers up too? Do I power the LCR with an amp, a receiver for some of the other speakers, do I need an impedance matching speaker selector (I'm not sure)...I just want some advice from every one out there who knows this type of stuff. All of my speakers are of 8 ohm nominal impedance. Do I wire in series,parallel, daisy chain, etc...
Please help.
Thank you
Hampton
markw
Why not just get a separate receiver and source for the second floor?
F
fergusonv
Use a Y splitter at the pre out and hook them up to thier own amps, you would be able to change thier levels individually with the gain controls on the amps.
AVRat
AVRat
For a “REAL” HT, I’d go pre/pro (Sherwood P-965, Outlaw Model 990) w/amps, or a decent receiver with an additional 4 channels of amplification out of surround pre-outs. More info on gear, room dimensions, and budget?
