Multiple line inputs on vintage amp
1
109rder
Anyone have an idea on the proper way to go about hooking up multiple RCA inputs on a Marantz 2270?
I already have a CD player plugged into the AUX. and I would like to run an HD radio tuner through the receiver as well. Should I try using the TAPE IN or TAPE MONITOR jacks?
Thanks in advance and happy Holidays.:
OttoMatic
OttoMatic
Hi there,
"Tape In" should work fine. I believe "Tape Monitor" will actually be sending a signal, so you don't want to use that one. There may also be other input options that will work.
Also, and not a big deal, but the 2270 is a "receiver" rather than an "amp."
Good luck and happy holidays.
