In the process of building a new house and its winter in MN. Lets just say I have a lot of time on my hand while I wait for a hole that needs to get dug and old man winter keeps delaying. Well at least I can take that time to research how not to spend my life savings on 18 sonos amps. After a lot of research below is what I came up with for 18 zones that are all controlled by an APP and voice controlled with Alexa. From what I found Klipsch gates are the cheapest alexa integrated streamer available for playfi. I believe this is a very recent update playfi did.
Hardware:
18 Klipsch gates (on amazon for $25 each)
2 Used Niles SI1230 amps ($200 each on ebay)
Klipsch playfi app (Free)
Klipsch Utility app (Free)
RCA to 3.55 adapter cable (2 to 3 bucks each)
I've tested this all out in the Rental I am in and had zero issues. I think the Klipsch gates are so cheap because of a firmware issue on disconnecting from wifi. I did not have any issues but did upgrade firmware right when I got them.
Here is the features I wanted and what this solution delivered on.
1) 18 Independent zones controlled from my app with volume control
2) Alexa integration on all zones/gates. "Hey alexa play 80's in the deck"
3) Group zones together
4) High bit rate from Tidal to a zone. Can't do this with groups not sure why.
5) Stream multiple sources
I'm sure sonos does a lot more stuff but honestly I don't care. The above features is really all I will ever need and it will allow me to put a couple thousand back in to my HT setup.
What you will need to pull this off.
1) Luck with buying niles amps on ebay. 2 out of 3 that came to be didn't survive shipping. You might want to pay a bit more and get one from a better seller.
2) Really good home wifi. Don't do this unless you have solid routers on each floor of your house. I will have an AP in my AV Rack dedicated for this. So home wifi might not be an issue if you can dedicate a Wifi router just to this setup in a central location.
3) Patients with updating the klipsch gates. You have to use the App to update the software then the utility to update the firewall. Both with work but a bit buggy. You just have to keep doing it over and over until it updates
4) Some Alexa know how: Getting the gates setup in the alexa app wasn't too bad.
** I have Klipsch CDT-3650's for ceiling speakers and am very pleased with the audio and can bridge channels on the niles amps when I need more power.
Here is a pic of one gate connected to one channel. They come with a 3.55 jack cable hence why you need the RCA-3.55 adapter.
