Multi-Room Connection Help
  • Thread starter Thread starter zetasoul
Z
zetasoul
1
0
0
Alright. I've been thinking about this for quite a while and can't seem to come up with a solution.
I have an old Harman Kardon AVR-330 that I want to put into good use by having it run a multi-room set up. I have 8 in-ceiling speakers and 2 in-celing subwoofers. I want to use 4 speakers and a subwoofer in one room and the same setup in another room. I don't know to attach a PDF to this post, so I'll do my best to describe the connections.
There are 7 speaker connections (8 ohms), 8 pre-out connections, 1 multi-out connection, 8 direct in connections. I don't even know where to begin to plug in all the speakers because there's not enough connections for 8 speakers and 2 subs. Is it even possible? What would I need?
Thanks.
