multi-ch input...??
Sounds Good
how does this work? i noticed i have on multi gh input on the back of my onkyo ts-dx777 what is an example of a multi ch player?
Sounds Good
so i would connect the R, L, C, RR, RL, Sub out puts from the player to my reciever via rcas?
Sounds Good
what is the advantage to doing this? whould hooking it up with a optical conection and letting the reciever do the decoding be just the same?
UFObuster
UFObuster
This is how DVD-A or SACD is played back. If you have a player that reads these formats, you must use the analog connectors. The player decodes the recording and sends multi-channel discreet lossless analog to your pre-amp. It's not compressed and the playback quality is finer. Using opitical works, but it is a compressed signal losing a little quality which is the whole point of using SACD or DVD-A anyway.
no. 5
no. 5
For SACD and DVD-A, that would not work, because of copyright issues S/PDIF (the optical or coax connection) will not carry the information from off those sources, and even if it could, you would need a receiver that had the decoders for DVD-A and SACD built in.
I would like to add that the other use for the multi-channel input is that of allowing you to access the high resolution audio from HD DVDs and Blu-ray discs with out using HDMI.
