MTX PS15 Amp Fried. Replacement help needed.
W
Whymee
I have a couple MTX PS15 home subs. I have had 3 amps in them from MTX. They all have fried. I would like to know what are my options on replacing the amps with something that would last? The stock amps will not last. I have to assume its a heat issue (no external heat sink) because I do not drive my system hard. Both of my PS15's are dead.
Currently I am using a MTX SUB15 and a PS15 on my system. I like the PS15 better, seems to have better sound. But I need to get the PS15 reliable.
I would not mind an external amp that would drive one or 2 PS15 spkrs. or a plate amp for each PS15. Keep in mind my disposable income is limited.
What are my options?
Thanks in advance
Stan
What is your budget? Have you considered stepping up to a better sub?
Seth=L
Seth=L
Thanks in advance
Stan
What kind of receiver are you using? If you are using a newer mid-fi or higher receiver then it probably has a cross-over. That means you don't need to buy one.
One point I would like to make is this, if all the amps have been damaged it seems that it could be a problem that might have been caused by excessive use. But an amp or amps that may fit the bill would be the Behringer A-500. It is rated at 500 watts @ 8 ohms bridged or 230 watts x 2 @ 4ohms. It should power the subs very well. The A-500 is around $180 a piece.
The only drawback to the A-500 is the lack of an "auto on/off" feature. If the sub is 8 Ohm, then the A-500 will work, but if it is 4 Ohms, do not use it as it is not rated to handle 4 Ohm loads when bridged.
W
Whymee
Thanks for the quick replies gents. My RX is a Sony DTR-DE975. At this time I do not want to upgrade the subs. I still have a working SUB15 from MTX. I just would like to bring back to life the 2- PS15's.
As far as roaching the previous 3 amps: The ps15 has a horrible repair record. A friend who owns a stereo store ( home & auto, out of business now) has seen several amp failures, so I am not alone.
Thanks for the replies... Keep them coming.
Stan
