I've never been one to buy into the whole 24/96 audio craze because I never heard a difference in an abx comparison. This does something different than regular 24/96 however. From the website :
the website said:
Conventional audio formats discard parts of the sound to keep file size down, but part of this lost detail is the subtle timing information that allows us to build a realistic 3D soundscape in our minds.
Without it, music becomes flattened. And our ears know it isn’t real.
With MQA, we go all the way back to the original master recording and capture the missing timing detail. We then use advanced digital processing to deliver it in a form that’s small enough to download or stream.
The result is astonishing. Every nuance and subtlety of the artist’s performance – every tiny drop of emotion – is authentically reproduced. When you listen, you’ll be transported right into the very moment of creation. You’re there.
In a nutshell, from what I've read, it compensates for the timing issues in both the AD converter in the studio, and the DAC during playback, eliminating the issues with digital playback.
So does it work, or is it just hype? I was pretty skeptical, but I figured I might as well give it a shot. Tidal is now streaming MQA on all of Warner music groups albums, so I purchased a tidal hifi subscription and fired up some tunes.
I don't have an MQA capable DAC, but Tidal includes software decoding. From what I've gathered the major differences between software decoding on a standard DAC and an MQA DAC is there is no "deblurring" on the playback end, just the recording end, and the maximum resolution from software decoding is 24/96, though a majority of studios rarely exceed this. I connected my receiver to my PC via Hdmi, enabled exclusive mode and forced maximum volume in Tidal and set the output to 2 channel 24/96 LPCM.
I definitely heard something different, tidal also had the original non master versions of several of the same albums, so I switched back and forth between the same songs to see if I could notice a difference. Immediately I noticed the Master version sounded like a veil had been lifted, it was if the focus had been dialed in to perfection, with incredible separation between instruments and fine details. The music sounded much more transparent and three dimensional, whereas the original lossless version sounded flat and blurred. There wasn't anything like extended highs or bass or anything like that, tonally it was the same as the original, just much sharper and realistic sounding.
To be positive I wasn't experiencing a placebo effect, I had my wife switch back and forth between the original and the mqa versions on several different songs while I recorded my guesses. I managed to correctly guess the MQA version on 7 out of 8 different songs. The music was the same level on both the masters and the originals so none of the mqa versions were any louder or softer.
So far, I'm convinced. MQA is most definitely capturing something that a regular lossless file doesn't. Has anyone else had a chance to listen and had similar results?
Sent from my SM-G360T1 using Tapatalk
