MP3 vs lossless for newbs
lsiberian
lsiberian
Nemo128
Nemo128
I've personally seen high bitrate MP3s be indistinguishable from their FLAC counterparts on Shure E500c headphones through a Sansa Clip and on Def Tech BP7006s. Those were blind tests though, not the biased junk many a snob reviewer goes through.
lsiberian
lsiberian
Have you tried some of the high quality classical recordings? I think that might be the only place where a difference would be discernable.
Nemo128
Nemo128
Remastered Bach and Beethoven. The FLAC files are almost identical but slightly more detailed in the high range. Then again, they're also about 4x as big.
Seth=L
Seth=L
I've been trying to listen to Yo-Yo Ma play 1B (flac) from the bluegrass stuff, keeps messing up every few seconds when the instrumentation gets complicated. I also listened Yo-Yo Ma playing Bach Suite No.1 in G major prelude (flac), but without incident. This was all on the Sansa Fuze 8gb model. The bitrate for 1B is 695kbps, and 590kbps for Bach No.1 in G major.
Seth=L
Seth=L
Dumbest thing, the display is set to shut off after 15 seconds of no buttons being pressed, the blipping starts when the display goes off. So if I set the display to stay on the blips do not occur, makes no sense.:confused:
