Rocky
Rocky
As most of you regulars know, I'm in the process of building a Home Theater in my bedroom. As I am a senior in high school, I was limited to just my room for now. Anyways, the space I have to work with is 8' x 10', which is quite small. I've got my front towers and center set up almost perfectly. Keep in mind, the 27" JVC tv is being replaced with a 72" screen and a SP4805.
Problem #1
The rear speakers are going to cause me a little bit of a problem because the room is soo small and I need to keep the speakers right at the back or else they wont sound like rears, and more like sides. I am pretty keen on wall mounting them to the wall in order to save space, but the right wall has no stud to attach to, and there is no accessable left wall, so the speaker will have to be mounted to the rear wall. Is there any mounting options that will allow a 90" pivot so as to allow me to mount the speakers to the rear wall where there will be an accessable stud? If not, what would you recomend as a mounting solution?
Problem #2
The projector. As mentioned before, the room is 8x10. 8 wide, 10 long. In the above picture you can see how the wall slopes in about 4' off the ground, leaving mounting a projector very tight. What would you recomend. Again, it would be nice to mount onto the sloped wall, but i dont beleive that there are any options that allow a tilt of that much. Also, keep in mind that a couch will be positioned below it and i dont want to risk standing up and knocking it off a shelf with my head.
Basically, both of these problems have to do primarily with ackward mounting, things that are not usually encountered in regular installations. Any help would be very appreciated. Delivery must be accessable to canada and online stores are A ok.
~Mike
