Mounting Paradigm Adp-370's
r33v35
I need a little help in mounting these speakers. I really dont want them to come crashing down as they are probley 20 pounds each. Does anyone have any tips.
JerryLove
JerryLove
Just a guess (IOW, when thinking about any heavy object to mount), use a stud-finder to make sure you are hitting a stud solidly and use a screw (or two).
20lbs really isn't that heavy for a frame to deal with; as long as you are not relying on drywall.
jcPanny
jcPanny
Drywall anchors
They also have drywall anchors that are rated for 50-100 lbs. These should work if the mounting location doesn't line up with a stud.
