Sorry, I should've offered more details. The box is rigged with very quiet vent fans in the side and rear that have done a great job handling airflow in the past. It's a nice setup, which is why I don't want to tear it up for my new projector. I just wasn't sure if having the top of the projector close to the flat bottom part of the box would be a problem. I didn't think so because the vent fans aren't on that side. It's also built relatively tightly, as it was custom-made for my original projector. There's really not room for the projector and a mount in the box as it is. I tried a Chief RPA mount, but you have to use the extra legs from the universal kit to fit the HD72's mounting holes. That makes it way too thick to fit in the box. I was envisioning making a low-profile fitted cradle (one forward, one aft) mounted on the bottom. The lack of adjustment is my concern with that.
Cheers,
Kevin
