Mounting 46" LCD on brick fire place
Celtics35
I am planning on mounting a 46" on my brick fire place. Does anyone have specific instructions to complete this with a tilt mount? Thanks.
Alex2507
Alex2507
I would use Tap-Cons. Home Depot carries them. 1/4"X2" long with a 5/16" hex head should do. For under $20 you get a bunch of the fasteners and a 3/16" masonry bit all in one box. You'll need a homer-owner (cheap) hammer drill, or you can probably find somebody in the parking lot to drill the holes for a six pack. :)
MDS
I don't really know anything about mounting to a brick fireplace but I would second the idea of using TapCon bolts because they are designed to be drilled into concrete/masonry. I would fear that a normal bolt wouldn't hold properly in brick.
Rickster71
Rickster71
Hey Alex, good idea with the Tap-Cons. (did someone say sixpack?)
Lead anchors are another option; though I like yours better.
With only four holes to drill, I think he could get away with a non-hammer drill. Depending on what type of brick; some are pretty soft.
It will take a little longer, and no added expense of a hammer drill.
Try to line up the mounting plate, so that all the holes are drilled into the brick, and not a mortar joint.
To run wires, I suggest something like this: http://www.wiremold.com/www/consumer/project_ideas/easy_home.asp
Alex2507
Alex2507
I honestly thought there would be more that just 4 fastening points. The reason I said to use a cheap hammer drill is because the carbide tipped masonry bit works best with the hammer action but you don't want a Bosch Bulldog Rotary Hammer Drill disintegrating the bricks. :eek:
Rick,
Unlike you, I am a fan of the mortar joint. Right or wrong, I have left a lot of stuff hanging in mortar, :D especially in cinder block construction. I wouldn't be afraid of letting a fastener land there as most of them would hit brick anyways.
Rickster71
Rickster71
Rick,
Hey Alex, how's things in Rhode Island?
You know what it is. I hang a lot of heavy switch gear, and other equipment; and ever anchor has to count and be solid.
It seems eight times of ten, the mortar joint crumbles and falls out when drilled, and an anchor put in.
With block and brick, they're manufactured under controlled conditions; where as a mortar joint, you never know it's quality. If it was a hot summer day when the block joint was made, it's going to have dried too fast, and be weaker.
It may work fine with Tap Cons, they don't seem to stress the joint as much as an expanding lead anchor.
T/C's are pretty strong, and the TV probably weighs maybe, eighty lbs.
Theoretically,;) one Tap-Con could hold that. I have four 5/16th inch lags holding up my 50" Pioneer.
We could meet up and mount the TV for him....if you don't mind splitting one six pack.:D
Rick
Alex2507
Alex2507
Split a six pack? There's hardly enough for one drinker, nevermind two. I just bought a Panny
TH-50PZ77U and am looking for a mount. Panny lists an Omnimount and I was just about to compare it to a Sanus. Any thoughts?
Is there an alternate location for the TV?
While over the fireplace may look cool at first, the height might get tiring after a while of watching at such an elevated angle?
Alex2507
Alex2507
Now that you mention it, that is the a very good arguement against placing the display there. Not using the fireplace is kind of an issue but staring up ALL the time is a huge problem. I was going to build a fake fireplace to house my electronics and set the display on the mantle until I got to the standard mantle height. Way too high.
Then again, maybe the OP doesn't have a mantle?
Celtics35
The living room is about 23x18. The far wall has the fireplace and shelving on either side. The side walls each have a picture window each taking up most of each wall. The wall oposite from the fireplace is where the entrance is to the room. The fireplace does have a small mantle that would not safely hold a large flat panel. I think the room is big enough to put the couch and other seating far enough back to the neck/eye strain will not be too bad. Thanks for your advice. I have sean lead anchors but have not seen tamp-cons. Thanks again.
Alex2507
Alex2507
A tap con is just a screw. It's blue and it's coarse threaded. You pre-drill a hole into a masonry product and drive the screw into the hole. They are very effective.
I hope you understand you can not use the TV when the fireplace is in use. It is well documented that the combination causes the TVs to fail and not uncommonly dramatically.
Rickster71
Rickster71
The small packages they sell at the Depot, also comes with the correct size carbide drill bit.
If you don't have have them already, pick up a few washers, just in case.
Yes, you can move further back, but then you tend to defeat the higher video resolution on the TV.
http://www.soundandvisionmag.com/assets/download/0602_tech_talk2_large.jpg
And, you will be back in the old days of watching a small screen TV:eek:
Preferably, the center of the TV or 1/3 up from the bottom should be level with your eyes when seated.
unreal.freak
unreal.freak
Can you point me in the direction of some more reading on this subject. I am considering mounting over my gas fireplace as well. I would like to read the ins and outs of this. Do you mean its ok to watch the tv if the fireplace is not actually on fire? I would think if you did watch the tv set while burning, it would overheat the set?
Thanks,
Tommy
bandphan
bandphan
Thanks,
Tommy
first i would measure the tempature where the mount is considered, second a frame of some sorts to reduce the temp around the tv. It seems aside the fact the heat is not friendly to our electronics, the viewing angle would seem to be off, even with pivot/pitch brackets. While it looks cool above the fireplace, it doesnt seem practicle. I would contact the manufacture and have them give an opinion. I would hate to reduce the life of any my electronics, and while i consider tv's a perishable elctronics item, my purchases need to be cost effective.
unreal.freak
unreal.freak
Those are good suggestions! I also read some of the directions that came with the firebox. It has a guide to follow when mounting the mantle. It has a chart that tells you how high to mount the mantle above the firebox, according to the size of the mantle. I'm using a 12" mantle so my mantle has to be at or above 23" from the firebox. I'm assuming that this is for fire safety purposes. Going to call Sony now :D Still looking for some reading material on this subject if anyone can point me in the right direction.
Thanks,
Tommy
Alex2507
Alex2507
I just noticed tthat you live in Florida! :eek: Why do you have a fireplace? :confused: Put a small picture of a fire in the fireplace, don't install the mantle and mount your TV at the optimal height. :)
I don't have any articles on why not to light a fire under your display.;)
unreal.freak
unreal.freak
The fireplace is for romantic purposes only :p In Florida it only gets cold enough for fireplaces a few days. But it is a nice thing to have on those days. We dont use the electric heat if possible.
I called Sony today, to ask about mounting the set over the fireplace. They gave me the number to a local electronics store who is an authorized Sony dealer and repair center. The owner told me that they mount flat panels over fireplaces all the time. He did say that he wouldnt recommend it IF there was no mantle. I told him i was gonna have a 12" mantle, and his reply was "no problem with mounting it there if you have a 12" mantle". I asked him about an extended warranty and coverage being null if mounted over the fireplace, He said it wouldnt affect the warranty in any way. They sell the Sony tvs, repair the Sony tvs, and even do repair work for other retailers including Best Buy.
Peace,
Tommy
