If your still wondering, I would go into the menu of the PVR, then setup, then audio setup and see what is selected there. For audio output make sure that either TV speakers is selected or if it is on Advanced the compression should be heavy. If compression is on light you have to crank up the volume on the receiver. Hope this helps....
