<font color='#000000'>In various statistics I have found what magazines call BI or motor strength which they say is measured in Tesla meters. How important is this to the performance of a speaker. I would guess it would be very indicative of sound quality, as would be moving mass (cone weight) power handling, and excursion capabilities.
Another quesiton, can anyone explain to me the relationship between how loud a speaker it and how much power is being put to it. For instance if you have a 12 inch sub powered by a 300 watt rms amp moving 7 milimeters, will it be the same volume or spl as the same sub moving the same distance with twice that amount of power. How is BI or motor strenght related to spl or volume, I would think it would come into play in the accuracy of the speaker, but probably it would be less indicative of overall spl, (you just have to get the air moving, it doesn't matter how bad it sounds). Assuming the sub can handle this amount of power easily.
Any reply would be greatly appreciated</font>
