Mnatiq,
On the back of your 806 are RCA (standard audio jacks) outputs that are labeled L, R, C, SW, SR, SR, SBL, SBR....this translates into the 7.1 channels of audio: Front Left, Right, and Center; Surround Left and Right; and Surround Back Left and Right--with the .1 being the subwoofer channels (SW)....
All you do is get high-quality standard RCA cables and run them from the pre-amp outs on the back of the 806 to the amp you purchase...This does NOT add to the power of your current receiver as the only amplified signal comes from the speaker outputs and with this you utilize the pre-amp outs....You then connect your speakers to the speaker outputs on the rear of the dedicated amp....
This might sound complex but it's really quite simple and I am sure if you check your manual there are some diagrams of such a set-up on how to use your pre-amp outs...
