Mordaunt Short 906 Tweeter
L
Lewis Sheppard
Can get some a pair of 906's for £60 but the tweeter has gone on one or so the guy has said. He is unsure if there is a problem with the wiring or if it actually is the tweeter. Anyone know where I can get one?
Most likely the tweeter not the wiring. Only place you are going to find one is probably through Mordaunt Short themselves since it sort of a specific tweeter. Those tweeters are mounted from the back since the front baffle is aluminum, and the only way to access them is likely from the rear (I don't see screws attaching the front baffle, I owned 902s)
L
Lewis Sheppard
Thanks. Any idea how much it could cost?
Unfortunately no. It is an aluminum dome I believe, but the waveguide is in the front panel itself not the tweeter, so perhaps not too expensive. They aren't so old so they possibly still stock them, but probably in the $20-40 range I'd guess.
