Monolith 7x200 Vs Xpa 9 Gen3
L
Lakers8/24
Okay guys I’m looking for a amp to power my front 3 channels and to have extra power if I ever want to expand my system.i am running a 5.1.2 right now I got 2 def tech bp9040 towers and a cs9080 center also from def tech my Pioneer SC801 is doing all the work so I was thinking about buy one of this to amps to take the work load of my receiver.so I’m not to sure watch way to go?can anyone help me out I would appreciate it..
Verdinut
Verdinut
I would suggest without any hesitation the Monolith 7. It has amazing specs. It's a beast and it weighs over 90 lbs.
However, before you commit to its purchase, I strongly suggest that you ascertain that the pre-out voltage from your receiver is high enough, to drive the required input voltage of 1.6v for the Monolith to attain its power ratings. You should be able to get this info by contacting Pioneer.
L
Lakers8/24
Okay thanks! I will definitely look up that info.
