I haven't tried their RedMere cables, but the RedMere tech is showing up in some newer cables from other companies as well. I would say that the added flexibility that this gives the shorter length cables can be invaluable for cable management and doesn't stress the connection point into your components nearly as much which is nice, but doesn't add or take away from the video quality.
Their slimmer cables are just more 'managable' but don't add quality.
Are they as good as your Audioquest HDMI cables?
Well, if you bought those cables at a store, and pricing was typical to this:
audioquest hdmi cable at Crutchfield.com
Then no, the Monoprice cables are not as good.
They are better.
Why?
Because they leave anywhere from 30 to over 200 bucks in your pocket and deliver the exact same quality performance.
In fact, this 6' cable from Monoprice for under $8.00 will deliver the same quality for even less.
For only $6.29 each when QTY 50+ purchased - 6ft 24AWG CL2 High Speed HDMI® Cable With Ethernet w/ Net Jacket - Black
Don't get duped into purchasing expensive cables ever again in your life if you can avoid it.
