boyblue
I have never worked with .ape files ,I recently downloaded a monkey audio file set to play in foobar ,but when trying to go from file to file the normal method will not work ,is there a secret?
boyblue
it's the file you get when you encode with monkey audio!
Adam
Adam
I thought that this would be a thread about Alex's new system. :)
Sorry, boyblue, I don't the answer. This is the first that I've heard of those files, too.
8
808htfan
I don't quite understand the question...
You mean you can't 'skip' to the next song?
You mean the file is a whole album stuck together in one file? If this is the case, did it come with a .cue file?
