Monitor Audio $400 plus shipping from 07073 I am the original owner and have all the original boxes and manuals. For the asking price you would be hard pressed to find a better sounding setup for both music and video. The equipment descriptions are as follows: PMC700 Front Speakers The 700PMCs (13 3/4"H x 8 1/2"W x 9 1/2"D) are two-way monitors with 6 1/4" woofers and 1" gold-dome tweeters. They are an 8-ohm load, and at 89dB efficient, fairly easy to drive. Rated frequency: 35Hz-30kHz +/- 3dB. The 700PMCs are a rear-ported bass-reflex design. CC700 Center Speaker Two 5 1/2" Metal Woofers one 1" Gold Dome Tweeter Rated frequency: 45Hz - 30kHz + 3dB Sensitivity: 89 dB, 6 Ohms Nominal Size: 6 ¾ " H x 20" W x 8" D Weight: 15 1/2 lbs. 1 Pair Lovan Ballet 24” Speaker Stands Links to Reviews: http://www.soundstage.com/video/revequip/ian03.htm http://www.sdinfo.com/volume_5_2/monitoraudiofullmetaltheater.html Links to pictures of the actual equipment: https://home.comcast.net/~bsacco4/Monitor_Audio/PICT0002.JPG https://home.comcast.net/~bsacco4/Monitor_Audio/PICT0004.JPG https://home.comcast.net/~bsacco4/Monitor_Audio/PICT0010.JPG
