ML Grotto OR 2x Dynamo - help please!
Bevan
hi, hoping you guys can help me out with this choice, between a martin logan grotto, or, for the same price two dynamos.
they will be for music only. and i dont listen at more than 80db. i'm wondering if the servo controll is of much benefit when the sub is playing easily within its limit?
thanks
b
jaxvon
jaxvon
I would personally opt for the dual Dynamo subwoofers. With two, you can create a stereo subwoofering setup that is superior to a single-sub one. You may need to invest in a bass management setup, but it will be worth it.
Bevan
thanks guys.
the two dynamos will be 1200, the grotto 1000-1200 depending where you read. that ML site has been down for a while so is not much help.
i was also favouring the dual subs. servo is no doubt good but at less than 80db i doubt it comes very much into play. what you recon?
they will be mated with a T-amp driving 101db zu tones(single driver speakers) so speed is my main concern. any other nominations at this price will be appreciated.
many thanks
b,
