markw said:
EQ's can adjust levels within certain frequency ranges but timbre matching entails a lot of acoustics that relate to the speaker type, diffraction of sound from the drivers, and other items that deal specificaly with the interaction of the drivers, crossover, enclosure and the room itself.
EQ's have their uses but to lay that at their door is like trying to use a band-aid to close a gaping chest wound without stiching it up
I quite agree markw.....
Malakei.... I'm a bit confused.... do you want to stay with Digms for your mains or switch to the PSB Stratus line? I mean the Stratus "mini" monitors are like a GRAND per pair or something like that right?
Obviously, it would be "cheaper" to stay in the Paradigm family and find a better set of fronts and center (the MOST important speaker in your HT system), and moving your existing Digm monitors to the rear for surround duty. That way you will be staying "in the family" of over all sound signature within your system.
To mix and match everything will work if all you want is "sound" coming from your speakers, but you won't have a nice balanced, over all cohearent sound field by doing so.
Just my $.02, YMMV, IMHO, FWIW and all that....
