Mixing Klipsch and KEF speakers in Home Theater?
G
grodzki
Hello. I'm upgrading my home theater system a little at a time. I have a new Klipsch RP-400C center channel, and am thinking of the next step of upgrading my Jamo S 803s to Klipsch RP-600Ms for new right/left channels. However, I am intrigued by the KEF Q150. Is mixing and matching different manufacturers in components a bad idea? I was told the KEF Q150s need more power to be driven...that the Klipsch center channel is far more sensitive and they wouldn't work well together. Any advice?
mazersteven
mazersteven
Your Left, Center, and Right should all be the same or from the same Family
I've mixed speakers for fronts but I prefer the same speaker across the front, or at least the same series. Surrounds it wouldn't matter as much, but even there I find the same speaker or at least same line all around is better for multi-ch music....
The Q150s are only rated at 86dB sensitivity, so they would take more power to reach the same levels as Klipsch generally (but Klipsch doesn't use a standard sensitivity rating, so to compare I'd take 4-5 dB off the Klipsch sensitivity spec)....but compared to your Jamo S803 with 87dB sensitivity, very close. Keep in mind it takes a doubling of power to gain merely 3dB spl, so the higher sensitivity speakers will lower your amp power requirements.
G
grodzki
Thanks very much for your reply.
