mitsubishi hc1500 setup question
K
krisztina
Hello Folks
I bought a Mitsubishi HC 1500, a 30ft HDMI 1.3 cable and a new upconverting DVD recorder a few days ago. When I try to set the recorder up with the projector either with composite or the HDMI cable I get no signal on the projector. When I hook up my old DVD player with composite it works fine. A couple of times I managed to get picture with HDMI for only a few seconds and after that back to no signal again.
I tested to see if the recorder is a lemon by plugging it into my TV (composite) and it works. I am assuming that the HDMI cable is OK as I saw picture on the screen for a few seconds. What am missing?
Thanks
Any help would be appreciated.
K
K
krisztina
Another bit of info...
I tried the DVD recorder with the projector thru component cables and it seems to work no problem.
None of this is adding up. Please help if you can.
Thanks
K
Johnd
Sounds like a cable/connection problem.
What player is it? What cable is it?
I would first ascertain that the connections are good...hmdi tends to loosen itself. If that fails try a different cable.
Finally, since you have witnessed a glimmer of a connection, it sounds like a cable or booster issue rather than a handshake issue. That is, a cheap, long hdmi cable is prone to failure. A simple way to see if it is a cable length issue is to get an inexpensive 3' cable (they're about $5.00) and see if that fixes your problem. If so, you then need a better cable, a shorter cable, or a booster.
TRod_228
No Signal - Mitsubishi HC1500
Hello all,
I used to have an Infocus 4805 and had it set up to view HDTV and regular cable using a TimeWarner DVR-Motorolla Reciever. Recently the bearings in the fan burned up so I decided to replace the entire unit. I purchased the Mitsubishi HC1500. I connected everything the same as my Infocus however, when trying to watch television any channel, I get "No Signal" on the screen. Even my HD channels aren't showing up.
My connections are as follows:
(1) Cable into DVR-Motorolla Rvcer
(2) HD Cables from DVR to Yamaha Rcver (DTV/Cbl Slots)
(3) HD Cables from Yamaha Rcver (Monitor Out Slots) to Mitsubishi HC1500 (HD Slots)
NO SIGNAL
However,
When I use just a single standard video jack from the cable box(yellow vid out) to the projector (yellow video input). I can watch television.
I've got an Xbox 360 connected to the Yamaha and it works when I use the Yellow video jack but not the HD.
I've tried changing cables and nothing seems to work. Any suggestions?
