F
frostbyte
I have this projector and have a black line all the way up and down the screen on the right side about 1/2 an inch from the end of the picture. Any clue what it is or how to get rid of it?
BMXTRIX
BMXTRIX
Sounds like a bad electrical connection with the LCD panels inside. Is it consistently black? Kind of weird that all LCDs would be affected, but it doesn't sound like an issue that you would be able to fix yourself, instead, it sounds like it is time to call Mits to get a repair.
F
frostbyte
It's constantly there. I'll have to look for a receipt since it was an internet purchase.
F
frostbyte
Anyone happen to have the info for mitsu direct off hand?
E
E-A-G-L-E-S
It's a DLP.
F
frostbyte
It was just some setting I had in it. I did a reset and it went away. I'll watch for it to reappear to try and figure out which setting did it.
Thanks. Problem solved.
