MinusTheBear needs your help!
Sheep
Sheep
Something has gone amiss with MinusTheBear's account on AH. His password is no longer correct, and he gets blocked after so many miss tries. Here is the message he sent to me to deliver to you.
"When I try to log into my account it gives me this message: Wrong username or password. You have used up your failed login quota! Please wait 15 minutes before trying again. Don't forget that the password is case sensitive. Forgotten your password? Click here! I also receive this message from AH in my email account: Your account on Audioholics Home Theater Forums has been locked because someone has tried to log into the account with the wrong password more than 5 times. You will be able to attempt to log in again in another 15 minutes. The person trying to log into your account had the following IP address: 127.0.0.1 Also tell them I created another account called MinusTheBear2 and it suffers from the same problem. Tell them I apologize for creating another account and it can be deleted. I suspect it is a bug of some sort but not sure. I am still unable to login at AH, even with the second account I created....strange. It locks each account for 15 minutes when only attempting to login once and then I receive an email stating so. I have also tried them on 2 different computers. I think it is something with vBulliten"
SheepStar
Matt34
Matt34
Moderator
SheepStar
Something is amiss. I've had it happen to me as well yesterday and Warpdrv advised me another member is having the same issue.
Adam
Adam
The cleansing has begun.
:D J/K! Something to do with last night's upgrade, I'm sure. I can't view who's online anymore, either. I'm guessing it will get cleared up.
Ares
Ares
Same here, could not log on this morning or most of the day till about 6pm central time.
vizionut
vizionut
I would have him run malwarebytes if he has it.
Must have been right after the updates last night. Was it updates or a purge?
rnatalli
Happened to me yesterday and I started having withdrawals... Luckily it worked fine this morning :)
Quickley17
Quickley17
Yeah... I had a whole list of threads I wanted to reply to, but promptly forgot which ones by the time I regained access. A good thing? Probably.
MinusTheBear
MinusTheBear
Thanks again Sheep. You da man! I can't hit you for any rep at the moment but I will when it will allow me.
Alex, you better stock up heavy on methadone. Your gonna need it when your AH account self destructs. :p:D
I also created a test account called MinusTheBear2 when I was having problems logging in. If it has not been done already, can the forum administrators or moderators permanently delete the MinusTheBear2 account. Don't do this to me EVER again :eek: :(. ....lol
Thanks all.
MinusTheBear
MinusTheBear
Welcome back! Glad to see that it's working again for you.
It just isn't the same without the daily fix. Good to be able to log in again. I was worried there for a bit yesterday.
speakerman39
speakerman39
Please save the bear.......s
Save the bear or the beer? :p:eek::p Perhaps, we can figure out a way to do both. Now, that would be grand.......LOL!!!!! No really, it happened to me several times yesterday as well. Something very odd is going on. Hopefully, a fix will be in place soon.
Cheers,
Phil
