monkish54
monkish54
Is there any interest in a mildly used MiniDSP 2x4 unit for $85 + shipping?
I have a pair of custom speakers being built that will use a MiniDSP 4x10, but they wont be done for a quite a while. I will use the 4x10 as a high pass for a pair of subs as well as a xo for the speaker.
I was thinking about buying a 2x4 unit to use with the subwoofers until my custom speaker is finished. Once the speaker is finished and I receive the 4x10, I will have no use for the 2x4.
Anyone think they might be interested in a boxed 2x4 unit with 2.1 xo software in, say, 6 months or so for $85 + shipping? The unit + software will cost me $115 + shipping.
MiniDSP 2x4 | MiniDSP
2 way Advanced 21 | MiniDSP
monkish54
monkish54
I would be using the MiniDSP simply for it's ability to be used as a high pass filter. One could use it as a digital crossover for a pair of 2 way loudspeakers as well as a wide range of other applications such as PEQ. :)
SearchofSub
After you use it just pass it around and I will re-buy it. Just take like $10.00 off for your use and I will buy it from you if I need it later fuzz.
