Brento
I'm short on depth with a corner built in wall unit . I want DVD and stereo capabilities but can only go 9.5 " deep. Is there a receiver out there that small?
Or should I be checking out mini systems ..... I need extra pair of speakers for ajoining room but most mini systems can only drive one pair plus maybe a woofer. Is there a system out there that will safely drive two pairs ?
mazersteven
mazersteven
Hello, What kind of a budget are we talking about?
Buckeyefan 1
Buckeyefan 1
I think you're out of luck. The smallest one I can think of is the Panasonic XR55, and it's much too deep. 9.5" is nothing. You may want to rethink your wall unit.
http://www2.panasonic.com/webapp/wcs/stores/servlet/vModelDetail?storeId=15001&catalogId=13401&itemId=93545&cacheProgram=11002&cachePartner=7000000000000005702&surfModel=SA-XR55K&catGroupId=25013&surfCategory=Receivers&displayTab=S
Even this tiny thing is almost 15" deep.
http://www.ubid.com/actn/opn/getpage.asp?AuctionId=10526842
mazersteven
mazersteven
I have a nice set up for him. And will work with his size requirement, but don't know what he wants to spend.
Here take a look at this. This is one way you could go.
Denon D-F101S: Executive Micro System
http://usa.denon.com/ProductDetails/1912.asp
http://usa.denon.com/DF101MB_productsheet.pdf
