Hi,
My first post here after obsessively researching and not really finding an answer. I'd like to improve sound quality in the great room of my house (a small converted church). Here's my setup:
-- Four Mission M77s (bi-wired with Blue Jeans Canare 4S1) located at opposite ends of 40'L x 19'w x 9-15'H vaulted ceiling. See architectural drawings attached. The Missions are the red boxes on the drawings.
-- Onkyo TX8050 receiver/amp
-- Sonos Connect running Spotify (320Kbps) or Tidal (Lossless FLAC) as well as streaming radio.
-- I play music only: dance, electronica, indie, eclectic.
-- Budget for improvements: $1,000.
-- Home furnishings tend toward rugs, midcentury wood, not a lot of soft stuff.
-- Great room has good height, lots of interfering trusses, and other complicated architectural elements, windows, etc, which I'm gathering might be helpful.
The story:
My preferred signature is warmer I guess. My mid-fi headphone setup is this: Senn 650HDs on a JDS 02 amp/DAC sourced from a MacBook running Spotify/Tidal.
I'm feeling like something is lacking. "Presence" might be a word. I just don't inhabit the music. The sound is "just OK". I thought it might be insufficient controlled bass. Maybe it is. I got a Sonos Bass module, placed it under the couch in the center of the great room, hated it and returned it. Too boomy and muddy (Not knowing at the time about proper subwoofer location). Then I thought I needed a sealed subwoofer... and started reading about room design... and source audio (I'm trying Tidal lossless now and can't detect a difference between that and the Sonos 320)... and now I'm slowing driving myself crazy. I have no idea where my low hanging fruit will be for a $1,000 upgrade. I discovered that I may have a problem with my speaker locations with my rear-ported Missions (6" from the wall at most) and near ceiling/wall corners -- all of the wires were installed inside the wall envelope when we renovated. (yeah, look at the drawings). Looks nice, but ugh no flexibility.
I have small children who will destroy any floor standing speaker (I think a sub would be fine though) as well as a wife who has zeeeeroooo interest in audio quality. Basically, I'd really rather keep our speakers where they are. Bookshelf models out of the powerful/curious hands of my children.
So, what should I be looking at? A sealed sub? A speaker upgrade? Try again with that Sonos Sub and place it properly? I tried a $0 upgrade by stuffing rags into the rear speaker ports and it just got rid of some bass which wasn't productive. Maybe an unported SVS setup? I just have no idea.
One idea: just upgrade 2 of the speakers on the living room side (where I do more focused listening) and leave the ones in the kitchen as is?
So there it is! Thanks for any ideas you might have!
Aaron
Floor Plan .pdf
https://drive.google.com/open?id=0B-KWtotXk7wUUUhUdW9pXzRGa0U
Elevation .pdf
https://drive.google.com/open?id=0B-KWtotXk7wUaUphaWJQYjZuU0k
